Rdwrv4
About to install canopy frame question 1 my frame is a little less than 1 inch shorter than the space between the panel and the turtle deck. The plans say to place it a 1\16 to 1/8 frome the panel I would like to know if there is a reason not to center it in the space. Question 2 the hinge is located .025 from the fuselage side? Question 3 how long should the hinge be? Question 4 is the rivet spacing longer for the hinge to longeron rivets? Any tips ?
thx Robin
