Wingit
Active Member
Just finished laying up fiberglass on canopy. Though I waited about an hour for the first layer to set up the tint added to make it look better from inside was diluted from the next coats . Is there a way to make it look better from the inside. Thanks
Dave
If you wan to see it black, like most cars have a band of black trip around the windshield, put a layer of carbon fiber on your layer. Not only gives much more rigidity, it will look black from inside.
Bonded trim
I fabricated one piece skirt and one piece trim. They were bonded with Sika. The primer is so black, it's solid black inside. Probably too late if it's layed up on the canopy. Just an option.
Canopy glass
Thanks for the info. As was mentioned After priming it looked great from the inside.
Thanks again
Dave
