I'm going to need a custom canopy cover for my tipover -8. No problem getting it made. Miss Patti's sewing machine is the equivalent of a CNC Haas and she knows exactly how to use it.
Here's the question.....what material makes the best canopy cover?
In it, he mentions using a "proprietary" reflective material, made especially for them, but also mentions Sunbrella. You can get Sunbrella at most fabric stores, and line it with a felt or micro fiber material. I might suggest that you get some sample pieces, put it under a slow speed buffer, and make sure it doesn't scratch or react with a scrap piece of plexi.
Odyssey Softouch is used by some aircraft cover makers, the fabric is a combination of an acrylic coated woven polyester with a soft non-woven backer of 100% polyester.
The weight is 11 oz. / sq. yd. and made by Marchem Coated Fabrics located in New Haven, MO. 573-237-4444
The Softouch fabric has a slightly different texture but is very close to the fabric used by Bruce's Custom Covers. (I have both here in my shop.)
This fabric would be overkill for a day cover.
http://www.marchemcfi.com/softouch.html
.... like it might make a good, lighter weight "travelling cover" that is still waterproof.
Careful here - per Bruce's advice, you really dont a truly waterproof fabric. It needs to breathe or you are inviting mold. Water repellent good, waterPROOF bad.
erich
