Wingit
Active Member
Does anyone know the size of the canopy clips. I can not find specific part # C01452. I do have a piece of .032 2 1/2 x 3/8 with 8 3/32 holes similar to what is depicted in the plans 38-28 but the plans call for a cs 4-4 rivets. I have a good fit without the clips but plans call for at least three clips. Thanks in advance.
Dave
You have to match drill #30 the clip and the canopy skin. Then you can rivet with CS4-4.
3 clips are enough if your canopy fit correctly.
On 38-28 it say to dimple the clips then separate, i am wondering if I have the correct clips?
Thank you
Dave
Those are really easy to make for yourself from the trim pack. But what you have in hand is probably it.
Thanks. If knew the dimensions I would know for sure and could either use what i have or make them.
Dave
As I recall, the clips to hold the canopy front down prior to fiberglass are a strip with maybe 8 holes drilled in it. The strip is about 1/4" wide. I think that I cut them apart then dimpled. they are really small once cut apart.
