Canadian builders - a couple of builders recently have had an issue with an inspector being assigned for final inspection, and that inspector saying that it is MDRA policy that RV's have a fuselage pre-cover inspection with the upper aft fuselage skin off. On the other hand, other builders have had MDRA inspectors do a final inspection without demanding a separate pre-cover inspection for the fuselage, and I have it documented by one MDRA inspector that such a fuselage pre-cover is not necessary, as long as you have removeable access and floor panels for any areas that might otherwise be hidden.
There are also issues where the MDRA seems to be over-stepping its authority by making-up its own requirements, such as demanding a stainless steel heater box, or demanding castle-nuts and cotter pins on certain items, where none of these are legally required.
Just wanted to call out to any other Canadian builders out there and ask what your experiences with MDRA have been like. I'm considering writing a letter to their central office to raise these issues.
Phil
Phil
