If so what are the steps to get the layers to bond? Im thinking about adding an extra layer to the stiffeners just because I am paranoid and dont want to have to cut into the rear baffle in the future.![]()
...it's OK. It is required to be able to bond to itself.
Just make sure it is clean with your usual cleaning/degreasing procedures.
As long as you have never had fuel in it, and have never had a leak through the area you will be ok.
I just want to clarify because I plan on doing this tomorrow... I have done the stiffeners, cap flange, and drain flange... getting ready for phase 2... Can I throw some extra proseal on the stiffeners just to be safe? Or do I need to do something to the proseal that is already there to get it to bond? Also, when I wipe the skins down for the ribs... will it hurt anything if a little bit of the laquer thinner touches the proseal thats already on the stiffeners? Or do I have to be super carefull with where I clean....
