I am starting my attachment of the canopy skirt to the frame and the canopy. I am in the conceptualizing phase, the part where I try to visualize the process and generally tend to over think the process. I usually find out after I get started that thing just tend to become much clearer once you get started.
I have already glued my canopy to the frame with Sikaflex. I have no problems with drilling some holes in the frame itself to hold the skirts in place temporarily but I really don't want to put any holes into the glued canopy. I have seen where some have used a few holes strategically drilled in the canopy to hold the top of the skirt tight during fitting and gluing. If this is what most recommend from their experience, then I would be reluctantly willing to do this also. What I am really interested in knowing is whether pressure needs to be applied to the skirt after gluing. If the fit against the canopy is good with the clecos holding the skirt to the frame, is this all that is needed to get a good contact and bond at the canopy? How is the aft part of the skirts held against the canopy after gluing to get good adhesion without the use of clecos? I was thinking Ziplock bags with sand in them my be enough pressure. Thoughts and comments welcomed.
