dmat Well Known Member Advertiser Jun 15, 2017 #1 Hi all, I did s search and couldn't find anything about it. Does the garmin 396 have the capability of running an external CDI? the plane has a old Navaid autopilot and I want to know if I can couple the two. Thanks, D
Kahuna Moderatoring Jun 15, 2017 #2 If the Navaid has the Porcine addition for interface into an external GPS, then yes the 396 will drive it. Link prior above shows the docs and description and below is the 396 wiring. Last edited: Jun 15, 2017
Larco Well Known Member Jun 15, 2017 #4 If the Navaid unit is to early to have the Porcine adapter built in try this link for more info. http://www.porcine.com/gps/sc/sc_frameset.html
