hi all,
i need a camloc with a weaker spring so i don't distort the piece of airplane the cam is mounted on. if i go to a longer shaft then the shaft does not fit properly when locked.
anyone had any luck shortening the spring so that the shaft engages the cam before you have to push on it?
