KentuckyMike
I had several questions about the camera and bracket used for my RV6 under wing mounted video
http://www.youtube.com/watch?v=jv6I98LFiBo
so I thought I would post a couple of pictures.
The camera is the Vholdr ContourHD. It only weighs 4.2 ounces and is fully self contained. It records to the included 2gb Micro SD storage card. The lens is 135 degrees in HD mode (1280x720) 30 fps and 90 degrees in SD (848x480) 60 fps mode. It is very small, 3 3/4 in length and 2 1/4 height and 1 1/4 wide. A 2 GB Micro SD card is included and it will accept up to 16 GB Micro SD. The average record time in HD is 30 min /GB and 60 min /GB in SD mode. I think it will record longer than the battery will last.
The bracket is just a piece of scrap approximately 1 1/2" X 3" bent in the middle with appropriate size holes. One is 1/4-20 for the tripod mount on the camera and the other to fit the tie down ring hole.
I start the camera recording before I get in the plane and stop it when I get out. The lens will rotate 180 degrees so which ever way you mount it you can still turn it to record level.
[/URL]
[/IMG]
![dsc00528small.th.jpg](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg43.imageshack.us%2Fi%2Fdsc00528small.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimg43.imageshack.us%2Fimg43%2F6066%2Fdsc00528small.th.jpg&hash=25e33452307a77bfac52a9e5bb0a9f77)
![](/community/proxy.php?image=http%3A%2F%2Fimg37.imageshack.us%2Fimg37%2F4936%2Fdsc00520small.th.jpg&hash=823278766017dbf0dc81fda7d42ec8d6)
![](/community/proxy.php?image=http%3A%2F%2Fimg44.imageshack.us%2Fimg44%2F4021%2Fdsc00522small.th.jpg&hash=5d501fb2586dff221bced1996ad4ec7c)
![](/community/proxy.php?image=http%3A%2F%2Fimg44.imageshack.us%2Fimg44%2F6447%2Fdsc00521small.th.jpg&hash=a119a488f682ea50d6ddc1837f7803ac)
![](/community/proxy.php?image=http%3A%2F%2Fimg94.imageshack.us%2Fimg94%2F6504%2Fdsc00523small.th.jpg&hash=80a2b995f8a7091a465e6513ddb25e11)
![](/community/proxy.php?image=http%3A%2F%2Fimg687.imageshack.us%2Fimg687%2F690%2Fdsc00524small.th.jpg&hash=9552eda4cb1c166567ef85aedf37a52a)
