If I wanted to accurately measure the height of a driven shop-head, what kind of caliper would I need? I know it would need to be sensitive to at least 1/128 inch. I've never used a caliper, but from what I've seen to measure the thickness of a part you have to put it between these two jaws, and close the jaws up on the part. But this won't work for measuring the height of a shop-head. Is there a special kind of caliper I can get for this purpose?
I'm still very concerned about my rivets being too short, and I'm hoping that it's just because my little rivet gauge is too fussy. My procedure is to set the rivet just enough so the rivet gauge will not slip over the shop head. But many times when I do this and then check the height, the shop head will slip under the height gauge, meaning the rivet has come up too short. My gauge seems to have virtually no margin between correct height and correct diameter. So I'm hoping with a caliper I will find that I am indeed within tolerance in spite of what that little rivet gauge is telling me!
(has anyone else experienced this phenominon, or is it just me??)
