E Ernie Member Sep 6, 2012 #1 Page 34-03, Step 4. I haven't located the details for these blocks need to fab them. Can someone send location information? Thanks Ernie RV12
H Hal-san Well Known Member Patron Sep 6, 2012 #2 they are part of the kit. If you did not receive them, let Vans know and I am sure they will send you a set.
S skydiverlv Well Known Member Sep 7, 2012 #3 4 wood blocks. They should be in subkit #4. 2 of them will be used later for axle alignment
E Ernie Member Sep 7, 2012 #4 Oh, I found two rectangular blocks 3/4"x1-1/4"x 3-1/4". Do these appear to have the correct dimensions? I likely tossed the others at some point. If they appear to be the correct ones. I'll make two more.
