Larry
Active Member
Where is the best place to buy the Dynon EMS-D10 and EFIS-D10A? Time for me to buy and I have seen so many places to buy from. Do not know who provides best price and service. What lead time can I expect?
I am about to install the plastic covering on the wing tip NAV and strobe lights. The method that Vans details seams a little light on retaining screws. Has anyone did it different and what has their experience been?
First flight projected for 1st qt next year.
Chief has the best price that I found for the 10A
$1995 for the 10A (which is cheaper than getting it directly from Dynon :confused: )
Some guys mount per Vans.
Some guys add additional screws top and bottom.
Some guys add additional screws bottom only.
2 Will Do
Larry if you do a good job of fitting and trimming the lexan wing tip light cover you can get by with 2 screws per cover, one top/bottom in the corner. I found mine fit well but on one, bottom side there is a slight loose fit, but I figure after I paint it it will be tight. If not I may add an additional screw along the bottom edge (like above). I hope that helps. In other words, try to get by with as few screws as possible, and two per side, in the corners is the min. George
Use tinnerman washers
If you do go with only 2 screws, my 2 cents is to use tinnerman washers to spread the load out a bit.
I've gotten by with 2 screws per side (one in the top corner, one in the bottom corner). It has survived hundreds of flight hours, a couple of flight tests past Vne, lots of yanking & banking.
Use more screws if it gives you warm fuzzies, but with a good fit it's not necessary imho.
Also, consider not riveting the nutplates in, but rather gluing/glassing them in place instead. That way you won't see the rivets on the outside (granted, filler/paint would hide that).
)_( Dan
RV-7 N714D (660 hours)
http://www.rvproject.com
Dynon
Check with Steinair or Safeair1.com. Both great to deal with.
Haven't flown yet but used 6 screws per lens to spread things out. I'll probably use tinnermans just for the looks.
Darwin N. Barrie
Chandler AZ
