rwarre
Still getting use to reading the drawings showing right side up and building upside down. I am trying to get the correct measurement from the f601 firewall to the front edge of the 604 bulkhead. I think it should be 29 1/2. Just checking since Vans is closed if anyone remembers or is building. The 604 does not set exactly perpendicular because of the wing angle.
Looking at sheet 23 (Bulkheads, Fuselage Jig), 29 1/2” is what I come up with. That is measured from the firewall web (front or back…..the .016” firewall thickness isn’t going to make much difference) to the aft side of the 604 bulkhead.
