rfchisholm
Active Member
Will an internet BLOG work as a record of the build, or do I need to have a paperlog as well?
Mel, a question along this line. I have a very good photographic record of my build but a rather sketchy written record. I'm wondering if I should go back to my photo record and written notes and create a written record that is a bit more rounded out? By the way lots of shots of me working on the plane.
A DAR is authorized to issue an Airworthiness Certificate, not so the Repairman's Certificate. The latter comes under the purview of the FAA. While it seems no two FSDO's interpret the regs in exactly the same way, in my case the STL FSDO issued the Repairman's Certificate on both separate occasions based upon nothing more than me offering up a couple of photo albums filled with detail photographs and a looseleaf binder filled with purchasing invoices. The materials were barely thumbed through. They were far more interested that the forms be filled out absolutely correctly. One such form took me three tries to get it right because erasing or crossing out the slightest error was disallowed.Will an internet BLOG work as a record of the build, or do I need to have a paperlog as well?
I got mine yesterday and even on the date that you sign the form, has to be in the xx/xx/xxxx that is 2, 2, 4 digits format. I did "9/1/ opps, you need to add zeros in front of the month" and I had enough room to add the zeros. Lucky I had not gotten to the year or I might not have had enough room for the '20'.There are a few "gotchas" on the repairman certificate application. Form 8610-2
Certification date of aircraft......09/09/2009
