What did most of you do to integrate the lower F-450 longeron into the F-404 bulkhead: Sandwich in between the U-plate and the -404 flange or just rivet against the U-plate/404 web flange stack?
I assume you want a minimal step off the U-plate for skin smoothness so wouldn't the sandwich approach be best? Same question concerning the floor rib, F-415 on the aft side of -404? Also, did you slightly bend the longeron at F-402?
Thanks for any help!
