ron sterba
My RV9A is complete and rigged from wing leading egdes back. The sequence for the instrument panel forward is the question. When we get the correct alignment here we should ask Doug to keep it posted somewhere in the forum. I have my IO 320 installed with oil lines and fuel lines. I have mounted my oil cooler on the firewall which is a Mod from Vans. Oregon Aero seats are installed. The instrument panels I have two of, factory kit and Vans 2" larger (trimmable) one in height, nothing done yet to panels. I bought the larger panel because I wanted to install switches under 10" Dynon and didn't want to cut the rib on top of the Dynon to fit it and a Icom A210. 7 switches and 7 circuit breakers. Relays are on the firewall and battery box made but not mounted.Spark plug wires are in as are the Injection spider and lines. My thoughts are that I have to mount these items and they are Throttle body, Baffle kit ( half assembled ). Catto 3 blade prop, flywheel and spacers, lower cowl and upper cowl,alternator, cables to lower center instrument panel, Air scoop under throttle body,hinges for cowling, forward top skin I think thats last to go in,exhaust pipes and mufflers ( Vetterman ), SafeAir pass thru tubes for probe wires and what ever wires,Transponder antenna,ADSB Antenna and com antenna. Pretty much as its laid out on my table. As I finally see the LIGHT at the end of the tunnel! I'm open FOR ALL of your builder ideas.
Again I can't stress enough how appreciative I am for you folks in my building of my QB. If you all have seen the instruction sheet for the Engine Baffle kit (9A) its like perfect! Hand to nose coordination! I wish Vans would rewrite the plan book for the 9A as they have done on the RV10 and 12. Its so sad to see in this site, builders selling their unfinished projects. They will never know the SMILE! Vans should be concerned that builders are not finishing projects. Some guys are in a RV community and then theres the ones who are not. I thank Doug for this site. OK, I'm going to the man cave NOW to work on the engine baffle kit. Thanks
Ron in Oregon
Ron in Oregon
