RVG8tor
I am tired of having to stop my build in order to have to go out to the store or wait for an order for what will eventually be typical consumables I will always need. I am talking about things like lubricants, sealants, primers, and touch up paints or other type liquids or semi-liquids. So what I hope to do with this tread is get recommendations/suggestions on what a builder might want to buy so that the items are on hand once the project progresses to a point where the items are needed. Some items like pro-seal has a limited shelf life so that would have to be purchased near the time it is needed. After I get a fairly comprehensive list I will post it under “Tips” with the various recommendations sorted by category, perhaps a link to an Excel file with the information as well. Of course anyone who has compiled this type of information, please pipe up. I am doing this because I found nothing under VAF search that provided the consolidated information. I will some I have read about, I will not mention a use if I don’t know one. If I am wrong about something please correct me, we can all pick up bad gouge from time to time.
Lubricants (please post where/what used)
LPS2 – General use- ideal for control bearings or other moving parts
Lubriplate-something to do with prop, I used this to grease the aileron bell crank bushing surface.
White Lithium grease-lube inner workings of the pneumatic squeezer
Silicone lubricant-adjustable rudder pedal guide tube
Sealants
Pro-Seal – Fuel tank sealer, general purpose adhesive as well
Permetex Thread Sealant with Teflon – Seal pipe threads like fitting into brake masters
Adhesives
Pro-Seal –general purpose adhesive (static ports, exhaust ramp vibration control)
RTV Blue – rudder and elevator crack control, or just to stick something to aluminum, the “Blue Ultra” I hear does not have any that will be corrosive or collect moisture.
Super glue – holed washer to nut while installing on bolts or holds shim in place until fastener is installed
Sealants
Adhesives
