Consider the APS "Black Steel" Nitrided discs. They should last several times longer than the originals. Aircraft Spruce sells them. You might need to contact APS via their web site to find the match for the make and model you have on your RV.
I am trying a pair and will compare them to some HD Clevelands shortly. I will use the Cleveland organic pads, so pad life will not change, but the discs should not scratch or rust even on an amphibian.
