GrinchF16
Quick question.. The left brake pedal for the right seat goes to the floor. Right brake works fine. Both brakes work fine from left seat. No leaks. Doesn’t quite make sense to me.
Could this be the internal o-ring in the brake cylinder has failed and is allowing the piston to move without creating pressure?
With no evidence of external leak I can’t figure out what else it would be that still allows the left pedal/left seat to function properly.
Thanks for input
Thanks for input
