I have to disconnect my master cylinder brake lines... (The ones with the plastic PT-062x1/4 high pressure tubes).
Does anyone know if the brass sleeve and its inner brass insert are reusable or not?
I've noticed that the brass sleeve gets distorted when the nut is tightened down on the elbow. Are people replacing these or just re-using them again if this fitting is disconnected?
Scott
DWG36a Brass Elbow Assembly G-10 section
Scott
