Mine's about 3/4" at the top of each pedal.
Remember that pad wear will not change pedal travel, though. As the pads wear, the pistons move out to fill the void, leaving the pedal stroke constant. The level in the reservoir will fall, however, as the pistons migrate outward as the pads wear.
