Started my rudder/brake peddle assembly. Have read about the locked brake issues and the proposed solutions. Was wondering just how frequent this problem occurs, how many builders are actually installing the springs on the Matco cylinders, and how many are using the AN3-60 bolt at the bottom of the brake peddles instead of the two separate bolts. Has Van ever commented on this problem? Seems like a service bulletin of some sort might be in order.
