I just finished my 40 hours phase one testing on my RV7A and discovered problems turning right after my first passenger ride. I checked the pads and the rivet was starting to rub. I checked the other side, same story, just not quite as bad.
These pads are shot after only 40 hours hobbs?! Anyone else have this problem? Did Vans issue Parker Haniffin Cleveland brake pads with their kits circa 2010?
My experience in automotive is you can buy cheap pads that need replacing in a year or less or you can try to find better quality which should last 3 years. I think vans supplied the cheapest.
Ideas, suggestions??
