msmst25
I am assembling the rudder and brake pedals, and using TS flightlines brake lines. I was wondering if there is any reason not to use the blue NPT fittings in the brake master cylinder, or if it is necessary to use the brass fittings. I don't know how to connect the brake lines to the brass fittings if that is necessary.
https://flic.kr/p/2kxedBn
Use the blue AN fittings, the brass fittings are compression fittings for use with the nylon brake lines.
