Tbone Well Known Member Oct 27, 2014 #1 While wiring my pump and flaps should I ground near units or single point ground?
RV7AJeremy Well Known Member Oct 27, 2014 #2 I ran individual ground wires back to the single point ground mounted on the firewall for the boost pump. For the flaps, see Walts Post below Last edited: Oct 28, 2014
Walt Well Known Member Oct 28, 2014 #3 Tbone said: While wiring my pump and flaps should I ground near units or single point ground? Click to expand... The boost pump would be fine with a local ground, check your flap wiring diagram and you will notice a local ground is not applicable.
