Flyweel bolts
Im working mine as well. From my blog.
Buy two long 1/2-20 bolts and two nuts. Put a nut on each. place the flywheel on the crank. screw the bolts in two holes then snug the nut against the flywheel. The remaining portion of the bolt is used to rotate the engine using a prybar.
