Bogi Bar Cups
I have an RV9a and when the Bogi-bar tow bar was clamped onto place on the axle nuts, it slipped off and removed a chunk of fiberglass from the wheel pant. This required a lot of hours for the repair and paint job. So I made a set of aluminum cups which are held in place by the front hex bolt on the axle forks. The cups are not exposed and fit underneath the fiberglass pants. I turned a few extra sets out of a solid aircraft aluminum rod. The Bogi-Bar fits inside the cups and the 9a is easy to tow around without fear of slipping and damaging the fiberglass. This is a very light weight alternative to the steel rods, longer axle bolts, and extra washers that are typically used for this purpose. If there is enough interest, I will start another run. The cost will pretty much depend on the number of folks interested.
