We used it on rod ends, cowl pins, etc on one of our RV9A's. It is very clean and effective, but stiffens up significantly in cold temperatures, to the point that you can feel it in the controls (slight but noticeable). Much more of an issue on the cowl pins in the cold, we cleaned it off and replaced it with our normal lps type lube.
