Bavafa
Does anyone know if Boelube is compatible with the canopy? The intention is to use Boelube for taping the screws into the roll bar as it needs some lubricant.
I wondered the same thing. I gambled and used it on the rear window with excellent results. Assuming that the rear window and the canopy are the same material, you should be go to go.
