Looking at the -12 plans, I noticed where it indicates to cleco te VS skin to the skeletal structure and then begin riveting from the leading edge towards the trailing edge. Final drilling and deburing isn't mentioned that I can see. Is that a difference from the -10 and this kit? Everything on the -10 was "final drill, debur". If so, that speeds the assembly quite a bit!
Thanks!!
Edit: I'm guessing you would debur every pre-punched hole even if you don't final drill, just because of the process used to make the hole.
Thanks!!
