rockitdoc Well Known Member Sponsor Aug 5, 2022 #1 Does anyone know a source for blind rivet equivalents for AN426AD3 rivets. I found Cherrymax equivalents, but they only seem to go down to -4 (1/8") dia. And the MK319-BS from Van's is not long enough for my application (AD3-5.5).
J jacoby Well Known Member Aug 5, 2022 #2 CCR264SS is pretty much your only option. https://www.cherryaerospace.com/docs/catalogs/CA-1036.pdf https://www.wicksaircraft.com/shop/stainless-steel-cherry-rivet/ (pic shows the 274 universal head)
ERushing Well Known Member Aug 5, 2022 #3 MK-321-BS The MK-321-BS is a longer version of the MK-319. I haven't been able to find a source that requires less than ~10,000 pcs order! Allegedly, they might be more available in the UK. If anyone has some, I'll gladly buy a handful from you!
mike newall Well Known Member Sponsor Aug 5, 2022 #4 CCC-32 from Spruce. Use them all the time when things get fraught....
rockitdoc Well Known Member Sponsor Aug 7, 2022 #5 mike newall said: CCC-32 from Spruce. Use them all the time when things get fraught.... Click to expand... Perfect. Thanks. S
Sam_B Well Known Member Sponsor Aug 7, 2022 #6 Cherry max cr3214 Try Cherry max CR3214. They only go down to 1/8” diameter, but they have the head of an AN426 AD3, so they are really like the NAS1097 “oops” rivet.
