http://www.vansaircraft.com/cgi-bin...-474&browse=electrical&product=wiring-conduit
States suitable for engine compartment. You could also order scat or skeet tubing for this purpose but I've seen many use the product above.
any advice how to attach this tubing to the baffling? I see nice flanges for 2" scat tubes but no good ideas for the smaller corrugated type.
We did manufacture a 3/4" flange but have discontinued them. Use a Uni-Bit and drill the hole one size smaller in the baffle that the conduit tube then use install the conduit and use a bead of RTV around the conduit to the aluminum to hold it in. It will not go anywhere.![]()
Or you could just skip them.
and make Brad's head pop off when the p-mags stop working because the silly little temp sticker stuck its tongue out.
P-mags get hotter after shutdown, yes?
The builder of my 9 put blast tubing to the one slick mag and also to the vacuum pump (dry). Are they even needed? Would rather not have the leaks out the back of the baffles as number 3 is running hot and it is only February.
As suggested... I did a temp test of the side of the Slick mag just after flight. 200 deg. F.
I put the blast tube back on... the mag has behaved well since that time.
I suppose I could generalize a bit and admit heat almost always is a bad thing. Unless it is directed at my feet in winter.... and then it bounces off the electronic ignition box on the floor. Some days, you can't win.
As suggested... I did a temp test of the side of the Slick mag just after flight. 200 deg. F. I put the blast tube back on...
