I feel a bit silly as this must be obvious for most. But I am wondering whether the blade antenna should be mounted with the straight edge leading and the sloping edge trailing or the other way around... My aerodynamic gut feel thinks the sloping edge should be trailing to help reduce turbulence and, hence, drag. But it seems that the common way to mount it is the sloping edge leading and the straight edge trailing. Thanks!
