BlackRV7
OK gang, the time has finally arrived, after the jump school pilot decided to play bumper cars with Black Magic last Memorial Day Sunday, to button things up this week. Just for the fun of it, I'm going to play and work this weekend. The play part will be throwing a picture up as I finish each scheduled item on my final paint punch list.
Everything is painted except the top of the cowl, which I again had to do some re contouring of the inlets to make it fit the bottom cowl, wheel pants, windscreen strip and fuel tank, along with a batch of screw heads. Yesterday between clients, yes my CPA practice is at my house, and it was casual Friday
, I hung plastic, put a filter in, fan in the window at the front of the garage and made a very small paint booth. Early evening yesterday I hung the wheel pants with safety wire off a makeshift set of stands with a bar between them and primed them. My curiosity got the best of me and I marveled in my accomplishment a little too long and knocked the bar down....with the wheel pants tacky still hanging
....Well, my weekend plans changed a little so, this morning I am going to wash the tank, acid etch it and prime it. While it is drying I'm going to resand
the wheel pants. When the tank drys enough, I'll hang the wheel pants ...again....(and safety wire the rod to the stands) and shoot those. All the while smooth priming the upper cowl, installing the old oil door from the original cowl...sand it and shoot it. As you can tell, I'll have multiply things going on, at the same time today..typical fiberglass work
With any luck tomorrow is paint day
Between all this, I'll be working on the forward deck and hope to install the fiberglass strip on the aft portion of the windscreen. I plan on painting the forward deck Weds.
I'll post pictures of each process as I go this weekend. Why you ask, just for the fun of it and my mouth has now written a check my !#$ has got to keep
I better get to work
![weekendwork004.jpg](/community/proxy.php?image=http%3A%2F%2Fimg509.imageshack.us%2Fimg509%2F38%2Fweekendwork004.jpg&hash=b505ca6188de9ca5b1f94366c0057662)
