After a week's of planning and coordination, my RV-7 finally arrived its new home at airport. Big thanks to Richard and Chris. The only challenge was the trailer is about 3' shorter than the distance from the main wheels to tail wheel. We had to bolt in a 2"x10" to support the tail. The 2"x10" extending 3' out doesn't look very strong due to the amount of deflection with loads. Since there is only about 40 lbs of weight on the tail, it is good enough for that. Just so glad this is done, and I am one step closer to the first flight.
