dan carley
i want to change the wheel pants, and am looking for the best way to just up the plane. any ideas
dan carley
dan carley
I used the lightweight stock jack from my Subaru Outback. I used a hose clamp on the gear leg to prevent the gear leg from sliding on the jack. This technique worked very well and seems a good lightweight solution for use away from home as well as at home.
Although they're currently out of stock, I've used this on both the RV-4 and my RV-6.
http://www.averytools.com/prodinfo.asp?number=561-1
