Might not want to use a chop saw on 4130...it's an air hardening steel. That means when cooled quickly (quenched) it gets very hard.
When you use a chop saw the cut end gets red hot. The rest of the tube is cold, acts as a heat sink, and quenches the end as soon as the cut is finished. Now if you must do some minor fitting with a file, saw, or similar....you can't. The quenched end is too hard.
Even more funny is the guy who chop saws to rough length, then tries to fishmouth near the quenched ends with a Joint Jigger or similar. Needless to say, the guy buys a lot of hole saws for his Jigger.
If you're sure of the finished length and the cut end is weld-ready (common with square tube structures), then the chop saw is fine. If you do ALL your trim and fit with abrasive tooling, it is also fine. And a chop saw is great for mild steel; it doesn't air harden.
BTW, the hardness disappears when you weld, assuming you cool slowly post-weld.
You'll want to outfit a bandsaw for steel if you're doing a tube and rag project....lots of sheet fittings to cut out. Try a Lenox Diemaster M-42 Bi-metal in 14-18 tooth variable pattern. Don't force the feed...let it cut at its own rate and it won't wear crooked.
