Some devices require multiple power wires in order to share the high current (ie, heated pitot tube, GPS Nav/Com, etc). I am using a VPX Pro and would prefer one (appropriately sized) wire to come out of the VPX. However, what's the best way to splice this single wire into multiple inputs into the device? Can I put the two 18 AWG wires on the GAP26 pitot using a single 1/4" quick connector? Or should I solder two 18AWG wires onto the 14AWG wire that then use two quick connectors to the pitot wires? What about when there are more than 2 inputs like on GTN 750 (7!)? I'm guessing it's better to use a terminal block and have multiple wires come off that?
