One More Slosh Data Point (sorta long)
I built my RV6 tanks in 1991 using the recommended method of roughing up the surfaces under the ribs, applying pro seal and brushing white slosh over the reachable prosealed seams before applying the back plate. Then prosealed and riveted on the back plate followed by a cup or so of slosh that was truly sloshed over the inner backplate.
Finished the plane in 1999 and after a couple of years noticed some slosh hanging loose inside, near the filler opening. Reached in and broke off piece. It was hard, postage stamp size. I have been flying the plane that way for these 14 years and because I have never found any slosh in a screen, gasculator or sump check have just lived with it.
This year, I decided to do the service bulletins in that area and check the slosh issue. Over the last couple of weeks I opened up the rear of both tanks. On the left tank, where I had seen the loose piece, ALL the slosh was tight except that little place I had seen earlier. On the right tank, where no loose slosh was visible, almost NONE of the slosh was tight on the back plate. The hole saw produced a nice aluminum disk (no slosh on either side) plus a nice white disk of hardened slosh. Same story in the other five bays. So much for process control procedures at this homebuilder "factory".
With access to check all the slosh I found it all firmly in place except for the right tank back plate. And boy, is it firmly adhered where it was properly applied. Then I spent some time reading VAF "slosh" threads. I found a lot about slosh removal and a lot of concern about slosh but no instances of slosh actually causing a problem. Talked to some folks around the Van's tent at OSH. Lots of concern but no one recalled loose slosh actually causing a fuel stoppage in an RV.
Because I am so impressed by how well the slosh stuck where it was properly applied, and because of concern about doing more harm than good (to me and my tanks) by going at it with chemicals, I decided to carefully remove the remaining loose slosh, seal the adjoining edges with proseal, close up my tanks and go back to flying and checking.
One more comment - this whole exercise was much easier than I had feared. Tanks came off easily, hole saw made quick work of access, closure plates from Van's worked well and the balloon stayed up this afternoon. After having checked it, I am comfortable with the slosh in there. If I sell the plane the buyer will know about it and can go forward from there.
Just a data point - not a recommendation for anyone.
