filiperosa
Hello,
Anyone knows the best way to replace the connecting rods small end bushing?
Filipe
Filipe
The process is outlined in the overhaul manual. Section 7-52 in the copy I have.
On a lark I added up the cost of all the tools and gauges they recommended. Only $44,951. I did not forget a decimal point..
Without looking at the manual, I'd have thought:
Pull the cylinder, pull the piston, unbolt the con-rod from the crank, save and mark the bearings for possible re-use. Send the con-rod to a certified shop to be rebushed, inspect and reassemble using new connecting rod bolts.
Clearly, I'd be wrong, huh?
