Okay, I'm struggling with the best method for sheet metal edge deburring. My builder assist coach taught me to use a file. I file down the edge to a flat, smooth finish, then file the 'corners' of the edge at about 45 degrees to round them off. I finish the whole process with a Scotch-Brite wheel. The edges are nice and rounded an smooth, but it is a tedious process.
Just to prevent confusion . . . I'm not referring to the corners of the sheet metal. Those can be filed or sanded to make a rounded corner
I see all these (seemingly) great tool built just for edge deburring. There's a dove tail (edge breaker) deburring tool and also a double edge (V-notch) deburring tool. Both look like they can accomplish the job that I'm doing with my file. Especially, if you follow it up with a Scotch-Brite wheel. Like all of you, I'm trying to produce QUALITY work, but maybe these short-cut tools can do both: 1) Quicken up the job and 2) Still produce quality work.
Thoughts on these techniques?? Is filing the best method or should I toss my file and go with the edge deburring tools?
Thanks! -Irishnavy
Thanks! -Irishnavy
