Mine are all around 45 ... the max is around 85 I think ... but if you get them too high it will bounce down the runway and be a handful on landing.
May bump the mains a bit after wings are on as I'm sure this will push them down a tad...
I finally found some guidance from Beringer in a manual - "4" which I assume is 4 bar or 48PSI. I put 50 in the nose and 40 in mains and looks good. May bump the mains a bit after wings are on as I'm sure this will push them down a tad...
TB
1 bar = atmospheric pressure = 14.5 psi. If the "4" is actually 4 bar then the pressure is 14.5 x 4 = 58 psi.
1 atmosphere at sea level = 14.6959 and usually rounded off to 14.7 here in the states. Must be a little less up north.![]()
Question for those with Beringer wheels/tires, especially nosewheels.
I've played around with pressure on my wheels - up to around 40 lbs, nosewheel looks more compressed than mains. What are folks using for mains and nosewheel?
Beringer manual recommends 3.5 to 4 bars for 5.00x5 wheels.
