Hi folks,
I am guessing some of you may have noticed that the return spring rates on the Beringer master cylinders is quite a bit higher than Grove and others.
The calculate out to me to be about 2N/mm. I have rocker toe brakes so can manually return movements.
Has anyone looked at fitting lower rate springs to improve progression and reduce overall pedal loads? If so what rate did you settle on?
