One quick note here:
In the Beringer install manual, they put the parking brake valve on the left pedal bar mount. That was different than we originally did our package, as some of you know. In most of the other installs, the PB Valve was located on the F14104 center brace to help control the length of the 2 extensions hoses for the 'A' model. And get it closer the RV10 location. Beringer in their manuals even show the F6122-1 trigear bracket mounted on the firewall, like the RV10. This doesnt exist in the RV14 or 14A and no provision for it.
So as a compromise, we had this beta tester mount it on the left pedal bar mount and in the case of the 14A, we'd have to extend the hoses to the main gear mounts. Those of you with 14A's know what I'm talking about. Steve and I didnt want to go against Beringer's 'recommended' location, although with the ALIR valve you are running hoses back and forth from masters, to the ALIR valve mounted in the center, then 2 hoses to the PB valve mounted on the left, then back across to the tunnel.
Personally, I thought it was unnecessary, but its what Beringer's engineers came up with. And, until we can come up with a better TESTED solution, the package with probably stay that way. Some of you previous clients have mounted the PB Valve on the F14104 center brace with excellent results. Some of you have made the RV10 style firewall mount work well. BUT, to accommodate everyone, we are going to use the Beringer locations for now.
Another note. Some previous clients or installers had mounted the ALIR valve either on the firewall or wall behind the center panel piece. LOL---my arms arent long enough to reach it when sitting in the seat with the harnesses on. YMMV. I wanted to move it aft, towards the seat and panel to allow easier reach during adjustment. Especially during initial settings of the anti-skid valve. It just didnt seem to me to be a safe way to be rolling, loose or not strapped in, braking AND trying to adjust a ALIR valve while reaching under the panel. it was mentioned by one poster that he assumed you set it and forgot about it. maybe so, but do conditions change? I think so, and I think you'd want easier access to fine tune that adjustment IF it became necessary.
For you builders that have the ALIR valve installed and FLYING, we'd like to know your impressions of both functionality and access for adjustments. Maybe I'm blowing this up, but certainly want to be safe here.
Tom and Steve---AS Flightlines
