storkeye
Member
Friend
I'm looking to fit a beringer anti lock regulator on my RV-7. However, with the rudder pedal assembly at the most forward 3" mark and the firewall recess fitted the ALIR won't fit on the bracket that mounts to the F-6115 plastic bushing.
I've looked around but I can't see many others having fitted a Beringer ALIR to an RV-7.
If you have one fitted how have you done it? Do you have any pictures?
Bracket
I fabricated a bracket but in the end decided not to install it. I didn't want the additional lines or another part in the system. Not flying yet so time will tell if that was a foolish decision.
Thanks Karl, the images are fantastic. I'm not sure why mine doesn't fit like yours does though.
Larry, I'm in two minds the regulator is quite heavy but other pilots I've spoken to have mentioned wheels locking up on grass and hard runways.
I think I might leave it to later in the project when everything else is in place and then decide.
