JurgenRoeland
I have a small and probably stupid question on construction of a bending brake. I'm at the point of bending my trailing edges of the elevators.
When attaching my doorhinges to the two wooden 2 by 4's, I have attached the wooden blocks clamped together and attached the hinges. This leaves no space between the blocks when the brake is closed.
Calling a fellow builder, he told me this will not work and that their should be a spacing between the blocks when the blocks are closed to allow for the radius of the leading edge.
On the other hand, I have seen pictures on this forum where the blocks were also closed. I'm a bit confused now on what is best
Can someone with elevator edge bending experience tell me what is the best technique. And if spacing is needed, how much this should be between the two blocks.
Thanks in advance for the info.
