Phil
Everyone has a builder moment where they slap themselves as say "Why did I do that?" This afternoon I had one.
I'm working on the HS and was in the process of removing a rivet. In the process of punching it out of the hole, I bent the (thinner) flange on the back side.
I tried to bend it back, but obviously the spring-back keeps me from getting a tight fit with the spar. This has resulted in an 1/8" gap between the rib flange & the spar.
Short of some major disassembly to replace the rib, I think I have the following options.
1) Find a way to bend it more. (That's the tip I'm hoping someone knows.)
2) Place a shim between the flange and spar and rivet through it.
3) Try and find some creative way to clamp it to the spar while setting the rivet.
Thoughts? How have some of you fixed this issue?
Phil
Phil
![DSC_3101-1.jpg](/community/proxy.php?image=http%3A%2F%2Fi141.photobucket.com%2Falbums%2Fr51%2Fphilperry9%2FRV-10%2520Build%2FDSC_3101-1.jpg&hash=11b96eccfed3a111f9ac639eec3a146c)
![DSC_3101-2.jpg](/community/proxy.php?image=http%3A%2F%2Fi141.photobucket.com%2Falbums%2Fr51%2Fphilperry9%2FRV-10%2520Build%2FDSC_3101-2.jpg&hash=15c5a7a9f57dc63a01c55691cb208e87)
