yankee-flyer
Finally had some cool weather after installing the Bender Baffle while waiting for new prop blades this spring.
6500 ', OAT 35 deg, CHTs with baffle open 170-175, air from cockpit heat definitely less than body temp.
Closed baffle, CHTs clowly climbed to 190-195, air from cockpit heat definitely too warm (bright sunshine but with Koger screen deployed.
Open baffle, everything slowing returned to original conditions. More experimentation (after I read up on max CHT allowed) needed to see if partial baffle is a possibility. But I WILL be much warmer this winter! THANKS to John and everyone else who helped on this.
Wayne 120241/143WM
Wayne - -
I tell people not to exceed 210 CHT temps. If it is 20 degrees, have to nearly close it to get up to 200 - 210. You will get good heat even then. For comfort, I have been most satisfied with this mod. Thermostasis Oil Therm is likely second best. I use the Moeller Fuel gauge the most regular I guess. Makes it a much nicer plane for year around fun. Thanks Wayne.
