Ron B.
I noticed a measurement missing for drilling the bellcrank to aileron pushrod. Since I have the RV-10 plans handy and the wings are similiar I thought I would look up the CS-00013. The RV-14 have a 13/32" measurement for the back hole location but no measurement for the front holes. On the RV-10 plans the front hole measurement is 7/32", but the part numbers are different. I drilled mine 7/32" and 13/32" and it worked out fine.
The revision 0 plans look to have a bit of a layout issue. The 7/32" measurement mentioned by Ron appears to be correct. If you look above the words for Step 2, you'll see a 7/32" measurement call out that aligns with the pushrod and first hole in Figure 2, below the text. I also drilled the first set of holes at 7/32".
Regards,
Logan
